Hi ,Adam,unit price :3500usd per unit .
I liked $1299 better. Better miners out there for better prices!
Hello Dave ,thanks for your feedback .
I’m interested but not at this price.
hi ,Badgerl,
Yes ,you are right .
Hi Just got mine from you.
But I’m having issues to connect to 2miners.com mining pool to min ETC
Do you have any config which works ?
If you are using 2miners for your pool use on of these for the url’s below:
For Europe: etc.2miners.com:1010
For USA: us-etc.2miners.com:1010
For Asia: asia-etc.2miners.com:1010
Next For The User You should put your wallet address in, then add a “.” then your worker name.
For example: 0x79a9FF58d1912C36768f6215aE6f38B5D4b775CE.1
So you would put your, walletaddress.workernumber
For the password it is simple, you just use “x”
Also make sure that you are mining etcash since your mining etc.
But If you were to mine a coin like ethpow you would use ethash.
Last thing you should look into dual mining coins like etc and zil
Thanks. If you have the E9 PRO.
I’ve updated the firmware (https://file12.bitmain.com/shop-product-s3/firmware/28cfd972-27e1-473e-a764-8bb7924213d6/2023/02/16/18/Antminer-E9-Pro-ETC-release-202302111632.bmu) to get ETC mining capabilities. Flashed like a charm
I’m not used to bitmain hardware the moment.
Is the algo ok for ETC ?
what sounds strange to me is that after rebooting, the asic makes a lot of noise for a few minutes. Then once the pool connection status is at normal, the sound goes back to almost silence. it this a normal behaviour until blocks are accepted ?
how long do we have to wait until the web interface shows a hashrate number ?
I do not want to wait the all night
any one being able to mine ETC with this machine ?
this is my first antmainer (I must do something wrong).
Looks like I managed to make it work with this pool
now trying 2miners.com
I made a tutorial
I made a tutorial.
E9 PRO Tuto
Great reply.
Thank you.
Hello everyone. I received my E9 Pro earlier this week. I initially struggled with mining pool setup/zero hashrate issues early on as their is sparse documentation for this miner at Bitmain. I want to send a heads up that to date, the miner appears to be limited to specific “Main” pools and is not able to connect to Nicehash, Unmineable, Prohashing, etc. I believe I discovered what Bitmain considers “Main” pools by viewing the E9 FAQ under their support portal. The link is here: https://support.bitmain.com/hc/en-us/articles/12711073390617-E9-FAQs
The E9 list of main pools is copied below:
I tested out several of the pools on the E9 list and they worked seamlessly with my E9 Pro. Hope this helps anyone who is struggling with finding a pool that works.
Happy Friday Sulfiroid!
Ezil.me provides a great dynamic configurator at this link https://ezil.me/start?pool=etc
Bear in mind that as far as I can tell, the E9 Pro may not be able to dual mine ETZ and ZIL. Flexpool stated it was possible but I was not able to get it to work. For Ezil.me, here is an example config for E9 Pro using the ETC firmware:
stratum+tcp://us-east.ezil.me:4444
ETC wallet address.work name (ex 0x4257f222222662711111682444ef561E79fE23e1.e9pro)
Any password (ex, X)
Thanks and I hope this helps!
