Product Overview
The Avalon Nano 3 is marketed primarily as a home-friendly Bitcoin miner and heater. Its key selling point is its ability to operate so quietly that it becomes almost unnoticeable in a typical home environment. This feature allows users to place the miner anywhere in their house without worrying about noise.
Key Specifications:
- Mining Modes: The miner offers three mining performance modes—low, medium, and high—with hash rates ranging from 2 to 4 TH/s, allowing users to adjust the miner’s performance based on their current needs and electricity costs.
- Power Supply: It runs on a USB-C power supply, making it both modern in design and convenient for various home setups.
- Connectivity: Supports WiFi connections, simplifying the placement of the miner without worrying about ethernet cables.
- Design: The Avalon Nano 3 boasts a slick design that can blend into any room’s decor, enhancing its appeal as a dual-purpose device that offers both functionality and style.
Setting Up the Avalon Nano 3
Setting up the Avalon Nano 3 is straightforward, making it accessible even for those new to Bitcoin mining. Here’s a quick guide on getting your miner up and running:
- Download and Install the App: Start by downloading the Avalon app from either Google Play or the Apple App Store.
- Power Up and Connect: Turn on your miner, connect it to your WiFi through the app, and link it to your home network by entering your WiFi password.
- Register on a Mining Pool: The default mining pool set in the device is Braiins Pool. Simply register there, set up your worker name, and you’re ready to start mining in less than a minute.
Choosing Your Mining Mode
- Normal Mode: Consumes about 90W of power and is recommended for regular use, producing around 3.3 TH/s.
- High Mode: Increases the power consumption to 140W for higher performance, suitable when additional heating is needed.
User Experience and Performance
Users can monitor and adjust settings via a smartphone app or through a web browser using the miner’s IP address provided on its display. This feature allows easy access to detailed information such as temperature and mining performance and the ability to perform firmware upgrades.
Practical Tips:
- Ensure you use the correct power supply to avoid issues like overheating, as experienced by some users with certain USB-C PSUs.
- Regularly check and update the firmware to keep the miner operating efficiently.
Conclusion
While the Avalon Nano 3 Mini Bitcoin Miner won’t make you rich overnight, it offers a unique blend of practicality and aesthetics, making it a valuable addition to any home. It not only serves as a source of passive Bitcoin earnings but also helps in heating your space, potentially reducing your energy bills. This miner is an excellent choice for anyone looking to dip their toes into the world of cryptocurrency mining with minimal investment and hassle.
