Hey guys, I have been following Vosik for quite some time now. I finally wanted to pull the trigger on my 4oo Acre renewable energy crypto mining. I have a budget of $1.5 million to spend on miners. So far I have (10) Goldshell
AL-BOX, (25) Bitmain Antminer S19 XP Hyd (255Th), and (20) BITMAIN AntMiner KS5 Pro. Can you recommend any other miners or suggestions for my project. Thanks
What exactly does “400 acre renewable crypto mining” mean? How are you producing the renewable energy?
Are the listed miners included in the $1.5mil or do you still have that amount left?
How are you running the hydro units?
Just a few of my many many many questions
I would suggest sticking with S21 and L7s. L9s are also coming out later this month. If i were you i would consider the long term maintenance required. In my opinion the above listed miners are the easiest to maintain. S19s are also a good option at a lower price point. You can get 500 S19 Pros for $250,000 today, but those are used and will require more to maintain over time.
