Any ideas how to run (2) L7’s 9500 on 1 bedroom luxury apartment (lease renting)
"Utilities may be used only for normal household purposes and must not be wasted. You must not misuse, or otherwise excessively use (as determined in our discretion), any electrical outlets or other utilities provided by us in the common areas."
"Unless authorized by statute or by us in writing, you must not perform any repairs, painting, wallpapering, carpeting, electrical changes, or otherwise alter our property."
… and lack of electricity is not the only problem. you should consider the heat and noise!
I assume a
does mean a condo with some neigbors next wall?
Because of the heat your would need to keep the windows open. with open windows the neigbors will go mad about you because of the noise.
So the missing power is not your only issue here.
No condo, just 1 bedroom apartment. Yes I have 2 neighbors one on each side. Seems my electric panel does have 240v maybe 208v since its 3part building. Was gonna get cancelation defectors and push the heat out living room window.
I could submit request for buildings electrician to stop by and see. Worst thing is say no lol And ppl that work in my leasing building are complete c()nts…
Also there are a bunch of video’s on how to make sound proof boxes. Some people use coolers, other build boxes from the ground up. Also look on pot growing sites for heat mitigation, and to a small degree sound proofing, i.e. light bleed.
Oh, also continue to look on tube for how to videos on rewiring that outlet of yours. Don’t give up, just take a baby step back, reorganize, then blast foward!!! Good Luck Dude/Dudett’
