30+MW Crypto Mining Farm Startup Question
I may or may not have access to low-cost green power up to 30 plus megawatts.
I’ve looked at a lot of 40ft container options.
However, if you had a choice to build a hard structure, what variables would you consider for which to is the best choice?
Also, what miners do you choose?
This will be a setup in the NV desert, so as you can imagine, it will get hot in the summer months.
geothermally cooled liquid immersion and a mix of algorithms.
