40kW Cooling Box with Water Cooling Tower
It can accommodate 6 Antminer S19. Scalable deployment.
Plate heat exchanger, power distribution, network switch and other facilities are all integrated inside the 40kW tank. Internal circulation uses oil, external circulation uses water, suitable for areas with sufficient water
