It seems like no matter what the settings, my memory temperature doesn’t want to stay lower than 94C.
Is this something to be concerned about? If so, how can I reduce it?
GPU temp is hovering around 52C, GPU (Hot Spot) 61C, 49.5 MH/s, 111W
current settings are -cclock 1200 -mclock 1750 -cvddc 750
BIOS is stock.
I was getting a higher hashrate with other settings but the mem temp was around 98C.
Edit: this is an MSI Gaming X model if that makes any difference. I read something about MSI MECH editions having problems with thermal pads, not sure if mine has the same.
