Anyone needing their 6 pin connectors replaced we offer repair services for them thru my shop
Mike’s_iFix
3125 Lone Oak Rd suite A
Paducah KY 42003
(270) 564-0486
Mike’s_iFix
Paducah KY 42003
(270) 564-0486
What causes them to burn out? Is it low quality cables do you know?
Not sure
This one was burnt using the same bitmain power supply shared with 4 other mini doge boxes running never been rarely been turned off since October 2021. lol these little machines are tanks
Nice one mate, I have cut a hole in my table with a hole saw and I stick my heat gun up underneath and hold in in place with vice grips and then also use another heat gun on top depending on the task, if it’s stupid and it works it ain’t stupid
good to see you’re doing repair stuff, I haven’t done anything in a few months
Hell yeah thanks man it’s a start from repair school we learned will be doing more as time passes and get to the more into the more difficult repairs too
