I noticed that this miner uses 1250 watts. So in theory it should work fine on a normal wall outlet that has 1800 watts and still be under 80% of the max 1800 watt load correct? As long as you don’t have any other power from that fuse.
1800 x .80 = 1440
Yes, but you will incur more electricity cost because it’s not efficient.
What causes it to be less efficient if I’m still under the 80% of the fuse amount? I thought the purpose of under 80% was to avoid overheating the power supply and thus fire hazard.
Do you mean less % of Amp capability equals more efficiency?
Whether it’s 60% or 75% isn’t the same amount of watts being pulled?
Appreciate the advice.
