What would work better (higher hashrates) to the single 5700xt I have right now, another 5700xt or 2 rx580’s?
Two 580s will give a slightly higher hashrate but use quite a bit more power.
if you go to Nicehash calculator you can hit comparison and enter the 2 types and see. You always have to keep the power costs in mind. The coin values will go up and down but the power costs are unavoidable.
it is always better to have less GPU’s making the same hashrate as more GPU’s whenever possible unless you live in the arctic and need additional heat year round
All this heat is gonna come in handy in the winter. I normally spend $200 a month for gas heating. I have a feeling I wont be spending any so another bonus.
our winter is about 3 months and the rest of the year is summer where I am
Lol, are you also in Texas then? Because it’s certainly been like that since I moved out here
right next door Louisiana where 80% humidity is low lol
I’m in Florida so it’s already hot as hell here
well geez…guess I’ll just get another 5700
think I’ll get the non xt one though… Thanks all…much appreciated
rx580 use 84-87watt with 32mhs,30-31mhs around 80-84watt from wall so both card give you 60-64mhs depend of settings
today in my country was 41c so it eat more 2watt per card more as fans runing 100% to keep 52-53c
Thank you👍much appreciated
no problem
i have 24 rx580 8gb nitro hynix
