Looking for advice on where to buy or get the parts complete set up for a mining rig and just general advice
First what’s you electric rate?
Pretty vague Brotha’ , but you’re in the right place. You need to be a lot more specific. Do you plan to mine with ASIC machines or build a GPU style mining rig. Location does matter as some venders may not sell to your nation. As the other commenter said, your electric rates/cost ?
Much of the info you seek can be started in Vosk video’s. He also has links on the video’s to the “real” source, not some fake website Bullshhh that is a scam. And I understand, you likely will not buy or build what Vosk has going on, but the general info is golden.
Depending how new you are, I would strongly suggest reading down this forum more. There are plenty of first hand accounts of most mining styles and Machines.
So to kind of ask some helpful questions.
Electric cost in KiloWatt per Hour (KW/h) at your location?
GPU or ASIC ?
How many extra amps of electricity do you have to use at your location? (if you can only plug in 2 miners before you blow breakers, maybe alter some plans) (60 amps, 3- 20 amps breakers, would be ideal to start)
Do you know how to transfer, sell and trade crypto? Wallets and storing crypto is 1/2 the battle, if your wallet game is poor you run the risk of losing everything to an oversight.
Something to consider right from the start, Do you plan on paying taxes and stuff Or staying off the radar, both are pretty easy but you need to pick 1 and stick with it.
You’re in the right forum to journey down this path. Good luck and Cheers. Good times ahead.
