I have 12 1660s GPU miners, i bought before thr market plunged in hopes of mining ethereum. Now that Eth has made it so you need validators in order to mine, im stuck in between a rock and a hard place not knowing what to mine. Can i get some advice on what I could do next? The GPU’s are sitting there not being used and ive thought about selling them. Please, i need some help
Sell or mine with something like NiceHash where it mines various algorithms selecting the most profitable at the time would be the easy answer.
Try checking hashrate.no and putting in your cards. Should tell you what the top thing is to mine.
Mine Warthog
Why nice hash and not betterhash?
https://powerpool.io/register?r=e6449094
I highly recommend and use this
, you can have your miner run on it they use NiceHash but you can change the layout settings to another coin.
You can also see other stats that is interesting also
I couldn’t recall the alternatives off hand and was more a general recommendation of using something that can get going with out serious investment.
