Air flow for mining
I’m running 6 miners…3 KA3 and 3 S19 141…
The KA3 are workhorses and have very little issues. The S19, days above 90 I can’t keep them going. I have 2 AC units running and multiple fans blowing outside air.
It’s to the point I can’t run them during the day… I live in MS.
Any suggestions
Do you have places for the out side air to exit?
I built a room in my garage and I keep the doors open during the day and about 24 inches at night.
You need to have one side where outside air goes into the location.
Then you have to face the intake side of the ASICS to the fans where the outside air goes in.
You will also need the other side to have fans so the hot air from the ASICS can leave the garage.
You don’t need A/C, you just need to keep giving the ASICS new air.
(You need to make a hot and cold isle, and have fans)
I’m going to remove the AC and add another fan to bring in the air… I have all the units duct to blow air out of room and also an exhaust fan…. Thanks for the info.
