I setup my ant miner kas s3 miner to only get hacked an.hour later. I brought the system back to default but something happened. Any suggestions?
what happened after resetting it to default?
Did you change the password on http from root?
What are the symptoms? Can you get to its status screen? Do the fans run up, leds flash? Has the ip address changed since I’m guessing you put it back to factory defaults. Can you ping it?
