Antminer L3++ low hashrate
I hooked up to Antminer L3++ last night. One is at 518 mh. The other is at 315 mh. Is there some firmware I can use with the miner to get it up to speed? No idea why it is down so much.
Any ideas why it is so low and any ideas on how to fix it?
Thank you
check all of the connections to ensure they are connected correctly. Check the power supply use the power supply for the miner thats working and see if that fixes it if it does then you have a bad psu. if not run it with one board connected at a time to see if its a bad board(s). use each board with all the data cables. It’s just a matter of elimination. Could be a psu, board, controlboard or cables.
Send us a screenshot. Are all the hashboards running and without error?
Anyone ever see this error message?
Get in touch with me … ill let you know why. or ill find out why if you still need :slight_smile: l3s my favs @Ebenn
Have you tried flashing the firmware? you can overclock or underclock using the antminer firmware.
Check your card in the inteface… 315 is too low, you might have bad hashboard. Sounds like only 2 board is working in that L3++. 518, it might be underclocked or you have bad/slow hansboards.
Can I ask why digibyte for scrypt mining?
I have two L3++ and one is running around 560 Mh is this a board problem. No errors on the dashboard.
Good question
unplug it and plug it back in . then click disable timer/do not use timer. and disable autotune. and reset chip freq
