Hello
I dont own an ASIC but I see Antminer L3++ with psu for $529. I think I would just breakeven but would own an ASIC. Hold for future bull run?
M
Hello
M
No. If you really want one they should cost $325-375 with psu but even then I’m not sure it’s worth it.
Do you accept L3+? A used L3+ is less than $200, while the APW7 power supply for the L3+ is only around $70. Seems like a better deal.
Thanks for reply. Yes probably too high.
Thanks fir reply. Probabky will pass.
