Antminer S21 200TH vs Whatsminer M60 170TH
All - relatively new to mining but been watching Vosk for over a year now. Want to get into BTC mining - which rig would you suggest? I’m looking at either the Antminer S21 200TH or the Whatsminer M60 170TH. Both are relatively new so would keep up well with the increasing BTC hash rate but not sure which of the 2. Open to other suggestions as well if there’s one I’m missing. Thanks!
I dont have experience with Whatsminer but ive heard that they are a lot more stable and dont break as easily like Bitmain miners do. Whatever you choose I would suggest researching repair centers closest to you for warranty and after warranty has finished just incase. For example the other day Vosk made a video saying his closest repair center for warranty cost him $20 in shipping. Well for me my closest repair center is 5000km away - Im in Australia and the closest is in Indonesia, so shipping for me is expensive. Everyones situation is different in terms of power rates, if you need to get repairs done, should you try to insure yourself better with immersion or water cooling but these are some things to think about and I hope that helps you make a more informed decision. Good luck mate
