How much panels is required for small farm
Depends what’s running at the farm on usuage
Rite now I have 5 avalon q, 4 etc ipollov1. 5 s9 bitmain. I got a quote for 16 panels for 22k. Im in va
Used asics has aload of solar panels used cheap try them
can you link the store youre talking about? id be down for some discount solar panels
also to OP, youre probably going to need a BUNCH of panels. just for the avalon q’s alone, that would be around 25 panels to just power those (ballpark estimates) unless you get more expensive/efficient panels
