I am about to make ANOTHER purchase for a K1+, I talked to Mining Syndicate amd they have not hooked one up yet and don’t know about the power on those. They mostly deal with Bitmain and Goldshells. I told them I would venture out and see how these are compared to a standard S19 when hooking it up to power. They didn’t know if they had to do anything special as far as plugs, ect. Any input is highly valued! Thanks guys!
They use a C13 plug just like a S19 does. Shouldn’t be any different.
doesn’t desert valley have one in stock? I thought I saw that he did.
Well that makes things easy! I thanks Adam for your feedback
Also according to specs it burns 30% less juice.
It’s been a few days since I looked but asicminersus had about 10, and seems to have a chat line directly to him.
He does some in stock ready to go, I just cannot afford the 38k price tag he has in them unfortunately
You can go with the used K1 model 5.3th if you want. I have it for sale at $10,950. Not sure what your budget is, but buying 3 of these is much more affordable and you get higher hashrate. Not much difference in power efficiency
Yep. Me too
I have a operation video tutorial, you can take a look
https://cloud.video.alibaba.com/play/u/2153292369/p/1/e/6/t/1/d/hd/291000488203.mp4
Thank you Ann! You have always been helpful
Single plug, very easy to use - mine have given me ZERO issues since I’ve had them!
you’re welcome, and we have K1+ in stock, if you wanna purchase another one and have any issues feel free to message me.
We are a partner of goldshell, you can order KD6 for May June in our online store, delivery on time, free logistics>>>>> www.bitpark.me
June future order address:http://www.bitpark.me/?product=goldshell-kd6-kadena-miner-26-3-th-s-june-futures
May future order address:http://www.bitpark.me/?product=goldshell-kd6-kda-miner
May and June future order address:http://www.bitpark.me/?product=goldshell-kd6-kadena-miner-may-and-june-futures
