ASIC PSU fans not working
Hello,
Having an issue today, powered on my ASIC and noticed KD5 PSUs fans not spinning. The unit fully powers on and the main fans intake and exhaust are working, I can access the webpage. It shows no hash on all 4. I tried another power cable but same issue. Anyone experience this issue before? Thanks for any input.
Maybe you can change a fan
Have you checked whether the output voltage of the power supply is normal? Has the PSU fan cable frayed? Try replacing the fan or cable, if the problem persists after replacement, the power supply itself may be faulty.
Goldshell saying it’s a bad psu. So I’m going to try a psu from my other kd5 and see if that works.
