ASICs vs. GPUs ROI Comparison
I’ve recently considered buying an ASIC miner and looked into the Avalon 1246 which has high regards in efficiency. One thing that I almost always see is the $ profits of ASICs and not the actual coinage amount per day/month. Prices change every day. I finally found a site that declared the BTC priced used in the calculation and it appears about 0.015BTC per month. By today’s $67000 price that is $1000/mo.
Then I started thinking about my mass slew of GPUs where 13x 1660 Supers generates about $1000/mo but only uses 990W vs. the 3400W the 1246 would use.
So why not just mine ETH → BTC via auto exchange?
There is more diversity when a single GPU goes down vs. an ASIC and less than a third of the electricity bill.
So why get an ASIC?
GPU is much more efficient in wattage than ASIC. It is very hard to buy GPU these days. If GPU is available, I would go with GPU mining. However, ASIC has is advantage too.
It is very simple. You don’t need to deal with the OS, the miner software … ETH 2.0 is coming, so you know you won’t be able to mine ETH soon.
