Hello,
Im buy the new avalon A1166pro 81th
But in 30 bays isent work 81 th?
Meaby is firmware to update? can i have link ? or diferent solution…
Hello,
how can check power(FMS)? how can i increase the power?
i buy her https://cryptosupply.de/ and ther is new.
MY LOG MINER
And thenks your support…
Hello,
Im fix thet,
ADJ(1) is a solution, in FMS is diagnosi and get command [{“command”:“ascset”,“parameter”:“0,aging-set,1”}]
This command is used for aging test, the aging test is to auto-tune the frequency and voltage of Miner ASIC to find the best hash rate and lowest power consumption .
The aging test will run 2 hours and the hash rate will fluctulate, please don’t interrupt the miner aging test ,if the miner reboot during aging test, the miner will run 2 hours again to finish the aging test.
I have teh same problem + a new one 3 days ago. I tried the fms command aging but it seems doing nothing. Looking at the log the aging parameter is 1 ADJ[1].
In the next lines I share the description of my problems. I’ll be grateful if anyone can help me.
I have an Avalon miner 1166Pro-81 since 1 month ago. It never worked at 81TH. In the config page the max TH is 68TH, but 3 days ago the Hash0 went to low temp, nearly ambient temp, and the TH went to 46 t0 48TX max.
It began when the ISP cutoff internet for aprox. 10 min (before that the miner worked at 68TH, afther that moment at 46 to 48 TH)
In my case Hash0 is wich “runs” at low temp. Hash0 it’s fine but is seems not to work (I cheched with the power consumption: 9,1A now in normal mode and before was 13A) After 5min that the asic starts, the temp in hash1 and hash2 goes up, so I finish turning off the asic to prevent damage.
Log after 5 mins
{‘STATUS’:[{‘STATUS’:‘S’,‘When’:0,‘Code’:11,‘Msg’:‘Summary’,‘Description’:‘cgminer 4.11.1’}],‘SUMMARY’:[{‘Elapsed’:230,‘MHS av’:34737202.73,‘MHS 30s’:47906044.34,‘MHS 1m’:44864068.60,‘MHS 5m’:20453743.08,‘MHS 15m’:8138892.82,‘Found Blocks’:0,‘Getworks’:10,‘Accepted’:232,‘Rejected’:0,‘Hardware Errors’:2,‘Utility’:60.53,‘Discarded’:1370435,‘Stale’:0,‘Get Failures’:0,‘Local Work’:1921,‘Remote Failures’:0,‘Network Blocks’:1,‘Total MH’:8041029101.0000,‘Work Utility’:488991.90,‘Difficulty Accepted’:1647523.00000000,‘Difficulty Rejected’:0.00000000,‘Difficulty Stale’:0.00000000,‘Best Share’:4942147,‘Device Hardware%’:0.0001,‘Device Rejected%’:0.0000,‘Pool Rejected%’:0.0000,‘Pool Stale%’:0.0000,‘Last getwork’:0}
{‘STATUS’:[{‘STATUS’:‘S’,‘When’:0,‘Code’:70,‘Msg’:‘CGMiner stats’,‘Description’:‘cgminer 4.11.1’}],‘STATS’:[{‘STATS’:0,‘ID’:‘AVA100’,‘Elapsed’:231,‘Calls’:0,‘Wait’:0.000000,‘Max’:0.000000,‘Min’:99999999.000000,‘MM ID0’:‘Ver[1166Pro-81-21072802_4ec6bb0_211fc46] DNA[02010000bfab6559] MEMFREE[1378296.0] NETFAIL[0 0 0 0 0 0 0 0] SYSTEMSTATU[Work: In Work, Hash Board: 3 ] Elapsed[231] BOOTBY[0x01.00000000] LW[187692] MH[0 2 0] HW[2] DH[39.252%] Temp[31] TMax[89] TAvg[61] Fan1[2668] Fan2[2681] Fan3[2632] Fan4[2635] FanR[34%] Vo[319] PS[0 1203 1276 144 1837 1276 1987] PLL0[8269 1449 789 3413] PLL1[4114 63 148 9595] PLL2[2522 192 484 10722] GHSspd[30081.28] DHspd[20.299%] GHSmm[66756.83] GHSavg[34864.27] WU[487048.22] Freq[399.65] Led[0] MGHS[68.49 17991.53 16804.25] MTmax[38 89 83] MTavg[33 78 72] TA[360] Core[A3201] PING[215] POWS[0] HASHS[0 0 0] POOLS[0] SoftOFF[0] ECHU[0 0 0] ECMM[0] SF0[370 390 408 428] SF1[370 390 408 428] SF2[370 390 408 428] PVT_T0[ 31 37 32 37 35 35 33 37 37 38 36 33 35 37 33 36 37 36 35 36 31 33 34 34 31 35 36 33 36 32 36 33 34 35 34 34 34 34 35 35 32 32 33 35 32 33 34 33 31 35 32 31 33 32 30 34 34 34 33 33 32 33 31 32 32 32 31 35 31 29 33 31 34 33 31 32 36 33 32 34 35 33 34 37 34 33 31 31 35 36 33 31 32 37 36 34 36 34 31 35 35 35 31 34 34 36 34 34 37 36 34 36 34 34 33 35 31 35 37 35] PVT_T1[ 76 83 80 81 83 80 80 83 80 81 84 81 80 80 82 83 83 84 79 86 86 89 85 81 78 83 87 86 79 80 78 85 86 88 80 79 79 82 87 85 84 82 78 79 81 81 79 74 74 78 80 77 78 75 74 76 76 73 75 75 69 69 64 71 72 73 73 74 71 71 73 76 75 76 74 75 77 77 77 76 75 74 76 79 76 76 74 75 78 79 78 78 75 76 78 79 79 78 74 78 81 81 78 80 77 77 79 79 77 76 74 77 77 80 78 75 75 75 78 78] PVT_T2[ 72 76 78 78 75 74 76 77 78 76 78 75 71 75 78 82 80 77 76 79 83 82 76 74 73 75 81 83 74 74 74 76 80 79 75 73 72 77 78 80 76 74 72 76 78 73 75 70 71 72 71 72 70 73 68 69 70 67 69 65 64 63 64 66 67 65 66 69 67 71 70 70 69 68 69 71 71 71 73 77 71 68 74 72 74 74 69 71 74 70 71 76 69 69 71 73 73 70 72 71 73 75 74 73 73 69 76 70 74 71 70 71 71 69 72 72 72 71 73 75] PVT_V0[245 247 243 247 245 242 245 247 245 244 243 244 234 237 239 246 248 247 246 243 242 240 237 238 242 244 243 246 247 247 245 247 246 245 243 245 241 242 242 238 241 238 242 243 244 241 242 241 246 245 245 241 243 242 246 246 249 245 245 247 257 257 258 247 250 249 255 254 258 248 247 250 262 267 268 423 423 425 443 445 445 460 464 465 409 414 419 394 394 396 384 385 386 393 390 390 415 417 418 403 406 403 406 407 407 421 421 425 412 412 415 457 460 455 435 434 439 401 399 400] PVT_V1[298 301 310 300 304 306 298 297 298 317 313 312 297 299 297 306 308 307 315 312 309 288 289 288 308 309 314 287 287 293 290 293 297 298 303 303 291 292 289 291 289 290 288 287 285 296 298 300 295 294 298 298 293 293 299 300 299 294 297 306 298 295 290 295 297 299 302 302 306 297 300 302 295 297 294 292 292 293 297 295 295 300 300 301 293 290 292 301 299 301 299 299 295 301 299 302 303 306 300 301 299 298 291 294 298 301 299 302 295 297 297 297 302 301 307 306 306 306 306 308] PVT_V2[294 305 306 295 296 299 292 294 296 309 311 313 297 295 295 303 304 306 290 287 289 291 287 287 289 289 286 295 291 291 282 283 282 291 292 295 307 310 311 289 290 294 291 293 293 290 294 292 299 297 295 310 309 308 305 307 309 297 300 305 310 305 307 307 309 313 308 307 306 309 308 311 290 289 291 308 305 309 304 303 303 298 295 295 308 309 305 300 295 294 297 294 298 291 291 298 295 297 295 297 293 294 289 292 292 304 301 303 302 299 302 309 307 303 302 305 300 303 305 311] MW[64754 64789 64708] MW0[0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0] MW1[4 2 4 6 6 3 6 3 6 6 7 6 5 5 7 6 2 3 3 4 6 2 4 5 3 3 5 5 2 5 6 1 6 6 5 3 4 6 5 2 4 5 6 6 6 5 6 6 2 4 3 4 5 3 5 2 4 3 7 6 6 6 3 1 3 3 6 5 4 2 5 0 6 1 6 6 2 2 6 9 4 1 2 4 10 2 5 5 2 6 9 1 1 3 3 4 3 2 2 5 5 1 3 6 6 4 4 2 1 4 1 3 4 5 3 5 3 1 5 2] MW2[7 4 1 4 6 2 4 6 2 6 5 8 5 2 5 3 2 10 2 6 5 2 6 3 6 4 1 1 5 3 8 3 3 6 1 1 4 1 8 3 5 4 0 5 7 6 3 2 2 7 4 6 2 3 3 2 2 3 2 2 7 1 4 1 3 4 3 3 2 3 3 5 6 2 7 4 5 4 4 6 3 5 5 2 0 5 3 3 7 5 4 2 3 5 2 4 4 5 3 3 7 8 0 2 4 3 3 5 3 5 4 3 1 3 4 5 7 3 4 6] ASICCRC0[0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0] ASICCRC1[0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0] ASICCRC2[0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0] CRC[0 0 0] POW_I2C[OK] FACOPTS0[] FACOPTS1[] ATAOPTS0[–avalon10-freq 370:390:408:428 --avalon10-voltage-level 44 ] ATAOPTS1[–avalon10-freq 370:390:408:428 --avalon10-voltage-level 79 ] ADJ[1] COP[0 0 0] MPO[3200] MVL[87] ATABD0[370 390 408 428] ATABD1[370 390 408 428] ATABD2[370 390 408 428] WORKMODE[0]’,‘MM Count’:1,‘Smart Speed’:1,‘Voltage Level Offset’:0,‘Nonce Mask’:25}
I partily solved the problem fixing the fans speed at 55% with a command via FMS soft, and the temp in the others Hash manteins in the recomnded limits, but is not permanet solution because if you rebbot the changes are lost. With this solution the temp of Hash1 and 2 doesn’t go up but the Hash0 it seems to be doing nothing and TH is about 46TH instead the 68TH (68 that have to be 81TH for this asic)
[{“command”:“ascset”,“parameter”:“0,fan-spd,55”}]
FMS download link: https://canaan.io/service/447
Have you checked your psu? One of my L3+ was only running with 2 hashboards. I had an extra apw7 so i figured why not lets give it a shot and to my surprise, all my 4 hashboards were back to working! Previous apw7 psu i used had been brand new, so it was bit of a disappointment but there is nothing you can do. Sometimes, you get bad apples in the mix…
Thanks, I’ve check it but the PSU is ok.
It could be something related to te aging?
Looking at the log the aging parameter is 1 ADJ[1]. Normaly It should be 2 after 10 hours of the last restart?
The log description documents that I downloaded from Canaan says: “Adj [1] is displayed before aging. When adj [0] is displayed, aging is in progress. When adj [2] is displayed, aging is completed. When adj [1] is displayed after restart, aging is in progress.”
looks like you are running in Normal Mode. I have heard rumors that running in High Performance mode is not supported by Canaan, but that would probably get you full advertised hash rate.
Would be good to have some other 1166 pro owners feedback on this issue since i have have this machine on my radar for a future purchase…
Good afternoon sirs.
I have some problems very similar to many of you. I have some Avalon 1066 Pro… and it seems that due to a problem with some cards, the machine goes crazy and starts running with the HASH cards configuration voltage at 1340. This voltage is automatic when the machine is at high performance, but In normal mode, this setting fluctuates at around 1260.
Even in normal mode, the machine plays at 1340. I’ve tried everything, but nothing works. I updated the firmware, used several controllers, but nothing worked…
The only way to temporarily resolve it is to use: [{“command”:“ascset”, “parameter”:“0,hashpower,1260”}], but as you know, when the machine turns off or restarts, it loses the configuration.
Does anyone know any way I can use this command directly in the cgminer configuration within Avalon? There is a field where commands can be placed, but this command doesn’t work there and even ruins the controller, where it only works again if I format it at the factory.
Thanks.
