What kind of banndwidth do you need per TH to reliably mine?
Thanks,
Terry
Thanks,
Terry
Good question! Hope someone answers you.
GPU’s can use GEN1 Pci-e on an X1 (single channel) so the bandwidth requirement is low. Sorry, cannot give you frequency or actual transfer rate
Thank You.
On the Bitmain website the say that a bandwidth of 1M will support about 200 miners. They were talking about the L3++ which runs at 580 Megahash/second. Below is a copy
Mining LTC with AntMiner (L3, L3+,L3++)
Litecoin are mined using a cryptographic algorithm called Scrypt. Taking L3+ as an example, we will introduce the operation process of mining with our AntMiner.
1. AntPool account registration and configuration
For details, please refer to " FAQ——Account Registration**"**
