The only good batteries like this I can get for the same USD price in my area is the Wattcycle 100ah 12v mini.
I need some for my pumps. So I am going to get 4 and put them in series.
The only thing is I am not sure if I could put 4 X 4 in series like the Ecoflow says they can.
If so, my build for a miner would look like this (Prices in AUD)
32 X wattcycle 100ah 12v mini: $280 each = $8960
2 X 48v 100ah mttp charge controllers: $242 each = $484 DC MONT 100A 12V/24V/36V/48V MPPT Solar Charge Controller - Built-in Bluetooth Backlit LCD Display, Solar Panel Regulator Compatible with Flooded AGM Gel Lithium-ion Battery : Amazon.com.au: Sports, Fitness & Outdoors
16 X greenbanks 550 watt panels: $330 each = $5280
Total: $14,724
USD = $9686
For 8.8kw of solar and 41kw of battery storage. This would suit me well as an example
Edit: this would be good for people who have very cheap off peak rates or an existing solar setup, to keep the batteries charged from the wall and to schedule the charger to turn off at X time based on your solar production or off peak rates
Second edit: if using off peak the batteries generally won’t have to be as big because generally depending on the plan, off peak hours are generally 12am - 6am and then 10am - 2pm, so a 3kw miner would need batteries I mentioned above.
Then, the price per day would be only 42kw discharge from the battery, so say 2.6c X 42 = $1.10 from the battery cost + 72 X your off peak rates. If you’re paying 3c off peak it would be $2.16 + $1.10 would be $3.16 per day for a 3kw miner which is under 4.5c/kw.
I also forgot to price in an inverter, but doing that for 14 hours off grid with off peak and inverter would cost
$400 usd for 2 X 48v to 240v 3000 watt inverters
$4400 for 24 batteries
Also ideal for someone renting
And this is all good as long as there’s no issues with inverters or batteries
Last edit: for context, my rates are midnight - 6am 5.5c usd and 10.30am-1.30pm is free.
So pay for 6 hours + 5 hours worth of charge (an extra hour of charge not to flatten batteries) is $1.80 per day before battery cost. Because you’d probably use 2 cycles per day, my battery cost would be $2.20 per day, bringing my total cost to $4 per day, bringing my true price per kw to 5.5c usd
