Best entry miner?
Brand new to all this.
Best place to start?
Goldshell KD Box. Best payout, low noise, low power (works with 110V) You can find on Ebay. Should be about $1,500. Alternatively you could buy a graphics card like the 3080 (not the LHR versions) if you have a desktop computer. This gives you long term flexibility as Easy Hash will keep finding the most profitable coin to mine for you.
Thanks.
I will look into this info.
I’m located in Scotland will check eBay.
Have you ever bought direct from Alibaba.com/ China?
