Trying to get started. Want to keep it simple, and start with something easy.
Where do I start assuming I plan to spend $1500 or so, and Ill be running solar power to a battery bank.
Normal AC conditions as it will be in my home (space I don’t use)
PS. I’ll spend more if I need to. $1500 is my low end.
Well, what are your goals with setting up a rig? Are you trying to learn about building a computer and tweaking it for mining? Trying to accumulate a specific coin? The answers to that really impacts what you should try to get/build.
Id like to be capable of mining ethereum, but short term Id like something capable of mining the most profitable short term currency utilizing the same or similiar hardware to what I would use to mine ethereum.
PS. Building the computer seems to be very fundational, so yes I would like to learn that during this first project.
It is way easier than you think don’t do like I did and go cheap if you are serious about doing this. I never built a computer before so I was very nervous going into my first build. I probably wasted about $500 on cheap stuff just making sure I could figure it all out before I bought some better hardware to make a real rig. My favorite GPU for the price right now is the AMD RX 5700 non XT. The MSI Mech version is one of the cheapest versions but it works great for me. I am able to get low temps with it while also using less power than my XT version.
The Nvidia 1660 super vosk just reviewed are very interesting at the price point
This is helpful, so don’t go cheap, and buy the Nvidia GeForce 1660.
Any chance somebody’s got a checklist of everything needed to build one of these machines?
Well, there’s been a couple of threads on here around this from myself, MeatyMouse, and one other person.
If you haven’t built a computer before, the first thing to do is figure out your list of parts. Vosk’s video on how to build a cheap rig for under $1,000 is a good starting point https://www.youtube.com/watch?v=r0s_Wj-6zyo&t=27s
At a minimum you will need a power supply unit, a mother board, a CPU, some RAM memory, some sort of hard disk (can be a USB for some builds), and of course GPUs. You may also want to get some sort of case or frame to hold everything, and possibly accessories like a cheap monitor, mouse, and keyboard to hook up to it.
The next question is if you want to get parts new or used? New is going to be more expensive, but also tends to come with warranties. Used is definitely going to be cheaper, but carries a bit more risk if anything is faulty. Personally I went for used, since I’m trying to keep it under $1,000 myself
Well, before going too overboard with shopping for parts, you should also figure out your electricity set-up. If you are hooking it up in-doors on residential electric, are you using a standard 120 outlet, or a 220 (like a washing machine/dryer would use)? That is going to limit how big of a rig you can hook up safely. You don’t need to buy a giant power supply or tons of cards, if you don’t have infrastructure to support them.
Putting it together probably won’t be as daunting as you think. But, if you have questions on specifics after watching that video, someone here can probably give some input.
cpu i3 will work fine
Motherboard I would get a mining specific MOBO like ASUS b250
ram 8 gb
PSU 850-1000W
risers and cables for risers
gpu’s
USB/HDD/SDD one of these three for you OS
rig frame
I’m a big fan of the trio builds. https://youtu.be/fOzz6YFSNxE old video so replace the cards with something more modern (or not) and use smos instead of nvoc.
here is the list of everything I bought so far I wasted some money so don’t use this list exactly like you only need one PSU that MSI motherboard was a waste because it can only run two GPUs.
if you do this build you will be under budget and making about 3$ a day mining ETH on Nicehash before you factor electric costs the total cost would be about $400 less depending on how much you spend on the PSU and the 3 AMD RX 5700 and not wasting the money I did.
You are looking for a shopping list like those listed above, but I will list a few items and tell you why you would prefer them:
MOTHERBOARDS:
Capability: The type of motherboard will determine the CPU versions, Memory SPEEDs, and Boot Drives you can use. The best motherboards $$$ are capable of TRI-MINING See this video:
Now that’s one hell of a reply!
You could start by mining on whatever computer you have now to learn. 0xMonero is easily mineable on an older model CPU or GPU.
