I get my IP address and open up the antminer page for KA3.
I have the latest firmware upgrade (Mon. Sep. 25, 2023)
I put in my Pool mining address (US)
I put in my minor name (wallet address)
I put in my password and I hit save …
and nothing happens no hashing!!
I sit here for 20-30 minutes waiting for to start hashing fans are working at a high speed.
It just runs at high speed and NO hot air!
This will be the fifth miner that I have set up and the third bitmain miner I have set up, so not new to mining. After a long while I will get a red and green light flashing on the miner, simultaneously.
I have a whatsminer M30S++ on the same router, that came up and started hashing immediately no problems at all.
When I received it, I opened it up make sure all the cards were in place and no chips were falling off the boards. I put it all back together properly and double checked it boards and wires are all connected.
Can anyone help, what am i missing??
email me the current logs and history logs
Sorry, wont be home till late tonight, i will send them to you tomorrow morning, around 10am central if thats ok.
Your miner ![]()
Sry…My uncle is in ICU and might not make it.
What is an e-mail i can send this logs to??
On the antminer site that i get, when i put my IP address in is saying i have an Abnormal Network Status + my Pool Connection Status also says Abnormal. I have it out in a shed in the back yard, and its about a 120ft run of cat 6 cable. But the whatsminer m30s ++ is running + hashing just fine.
Sounds like something with pool address…
That is exactly what it was. Changed pools and the Network abnormal went away and then the pool mining abnormal went away, 3 minutes later it started hashing!!
