Bobcat 300 Placement Advice Needed
I live on the ground floor of an apartment building surrounded by 15ft walls and no way of getting the bobcat miner to a higher elevation. Would you still recommend I purchase the miner or not given my situation? Thanks in advance!
Check the network grid map where you live. If there’s plenty of hotspots close enough then you can still earn a decent amount just placing it in your apartment. That being said, I would also check the earnings of hotspots in your area too. If they’re not making make much then odds are neither will you given your situation. Another option is to place the bobcat in someone else’s home. I have one of my Sensecap miners at a friend’s house and I’m roughly earning 9 HNT per month at that location alone. Since he’s hosting my miner I agreed to give him $40 a month as long as my earnings are consistent. You might be able to make a similar arrangement if your earnings are high enough, if not higher
