Bobcat 300 rural location
I live in a rural area. Will the Bobcat 300 work well if there are very few houses/businesses within three miles? Thanks
check the post I just did on the other thread about Bobcat scalping prices. bottom line is you need to check the helium explorer and confirm there are miners around you. If not then you will only make about $8 per month.
