My long term goal is to stack sats but not ready to get a big ant miner. Would it be for a newb to go with the gold shell doge minis and convert the coins to BTC. Also do I still need to install a 30w 240 line to run a couple of the minis. Any other advice would be helpful. I have about 5k to get started investing in mining. Thanks
Hey Rick,
Newbie here myself. I would suggest buying a few AntMiner L3+ on Ebay and verify the sellers reviews. The units will run you about $1400-1500 a piece lots available i would go refurbished on them with a PWR supply included. These units will mine Dogecoin + Litecoin together depending on the mining pool you select. I will be using NiceHash for minning on PC and with the L3+.
Here’s a link for the L3+ with additional specs: Bitmain Antminer L3+ (504Mh) profitability | ASIC Miner Value
