Can I buy the KS1 control board, psu, fan, cables to mine Kaspa? So instead of waiting to buy a KS1 I can just build by buying parts. Is this possible?
Technically yes you can buy control board, fans, cables, spare hashboards, power supply, you’d need a case to put it in for airflow, however buying things like a single hash board normally comes at a huge premium and I wouldn’t recommend doing this, if you tried to 3D print a case and the air flow wasn’t good then you could cook the miner, so much could go wrong
Ok thanks for the tip
