I’ve just received a 20ft Conex Box for my mining operation and I’m looking for different people takes on what to do with the space inside. If it was yours, and you had a reasonable budget, what would you do with it? Shelving setups, shelving orientation, Power panel capacity, Power panel location, ventilation options, air flow direction if applicable, Internet, miner types, miner models, security.
