Can someone please help me?
Hello. I have my hotspot relayed. My setup is this: I have a main router (which I use to connect everything to the internet) that is connected to another router via cable, that sends wifi to my hotspot. I did this because the range of my wifi on my main router was not reaching the hotspot. My question is this: do I have to open ports only on the second router, that is directly connected to the hotspot, or do I have to open ports on both my second and main router? Thank you.
refer ti the helium wiki we have here. but you should just need to open up port 44158 on the main router, however i think in a few weeks port fowarding wont need to be done anymore.
p.s. if you need more help you can join the discord and ask for paul in the helium section. he has a whole system for helping ppl get out of relayed status. as well as UI he created called H.A,M. for management
thank you very much, internet stranger.
Isn’t it something like the 24th April or thereabouts when port forwarding is no longer necessary?
