Ive downloaded software and driver and it keeps telling me error, disconnect the network??? What am I doing wrong? Anyone
Anyone😂. Thanks in advance!!!
Hi make sure your typing your workers info correctly i.e. mining pool web address, port number, worker name.
Make sure your PC or laptop recognize your device. Check device manager.
Uninstall then reinstall the program.
If your using a VPN try switching to another location (server). Sometimes this helps.
Just a few things you could try. Hope this helps.
All helped and worked perfectly!! Thanks for the input
