Can you mine binance coin and if so how do you do it?
Thats a nope
Technically you can via unMineable but it’s not really the best software because when I gave it a go mining other cryptocurrencies it was making my mining rigs more hotter than normal.
Don’t forget to add the recognisable memo from your bnb wallet too so that unMineable transfers to your wallet correctly.
But personally after trying and in my opinion it’s not worth it.
But if you’re that bothered to mine bnb then do so at your own risk.
