Just started mining chia with my laptop and external memory 82TB… How many plots should I expect to farm. My laptop only has an i3 core but everything else is in speck to what I’ve read.
Thinking about updating my computer but not sure yet if the juice is worth the squeeze.
From my understanding CPU is mostly a factor with plotting the rest of it you don’t really need CPU power for. You have to plot before you can farm so if you have access to something else to plot with that might help you.
Plotting in parallel or one at a time and have them queued up? With a lower CPU I would not try to do in parallel until you have 1 or more plots already up. I believe it is possible to plot from a different device and then farm with something else if you have access to a strong CPU for some extended time given the size of drive you want to fill.
So this is an interesting option and wondering for this and may be in its FAQ but this will never need the full node so in theory one could trash the full node data once they no longer need the base chia app. After the initial plot is built does FlexFarmer build additional plots or would one need to build all the plots on the Chia software and add them to the FlexFarmer?
I did that CPU plotting with Mac mini m1 just to try and it takes a long time. You need around 3500 plots if your electricity price is not high. So it takes months to plot enough and many drives which is hard to connect to your system. I would say that dont go on with that laptop road, just to try it is ok but otherwise no point to do that.
If you are serious about CHIA farming I would look at a dedicated server rigs with at least a Ryzen 7 and couple hundred TB of storage or just getting things like the Evergreen and Jusey miners.
