So, I am looking for advice on my next miner(s). I currently have two KD Box Pros, six Mini Doge Pros, and two HS Boxes. I have about $1k to spend on more miners. With prices like they are, it seems like the right time to buy.
So, should I add another KD Box Pro, four more Mini Doge Pros, or something else?
The difficulty on each of those is going to increase a fair amount in the near future so I’d go with something else. Maybe an SC or CK box to diversify? If I had to pick from the two you mentioned, I’m partial to KDA.
Thanks for the advice. I am pretty new to mining. I think I may wait a bit and just let my coins grow. I will look into the two coins you mentioned. Are there any miners you would recommend?
I’m a big fan of Goldshell’s Lite miners. Good price point and can be run on 120v. Can get a LT, HS, LB, or CK Lite for under $2,000. The LT Lite, for example, is like having ~8 mini doge pros in one.
Just a thought.
Good question I am new and have 2 L3+s and am getting a bit obsessed lately. I am not sure if I want the HS Lite or the LT lite. I keep bouncing back and forth and the wife says only one right now, so it needs to be a good one.
How about an HS Lite and a mini doge pro since it’s less expensive than the LT Lite?
You aren’t that far from buying a partial BTC ASIC if you can host it. The S19j pros and WM M30S++ are around $4500 now. Do you have a few friends to pool your money together?
