Whatsminer M56 178Th/s~194Th/s 29J/T For Sale, BTC/BCH/BSV, SHA-256 algorithm, maximum hashrate is 194Th/s, maximum hashrate is 5550W, Oil Immersion Cooling Mining. The size of the whole machine is 267147401mm, and the weight of the machine is 13 kg. It can be directly connected to Ethernet for use, which is very convenient. The suitable operating temperature of the machine is 0-40° C. Miners are requested to operate in the range of temperatures to avoid damage to the machine. The power consumption ratio of the machine is 29J/T, and the working humidity is 5-95%RH.
Specifications
| MANUFACTURER | MicroBT |
| MODEL | WhatsMiner M56 |
| ALSO KNOWN AS | WhatsMiner M56-194T |
| RELEASE | January 2023 |
| SIZE | 267 x 147 x 401mm |
| WEIGHT | 13000g |
| NOISE LEVEL | 45db |
| COOLING | Water cooling |
| POWER | 5550W |
| INTERFACE | Ethernet |
| TEMPERATURE | 5 – 45 °C |
| HUMIDITY | 5 – 95 % |
Introduction of Whatsminer M56
The Whatsminer M56 is a powerful and efficient Bitcoin mining machine produced by MicroBT, a leading manufacturer of cryptocurrency mining equipment. Launched in 2023, the M56 is one of the most advanced mining machines available in the market, offering a high hash rate and energy efficiency.
The Whatsminer M56 is built with advanced ASIC chips that are designed to deliver a hash rate of up to 194 terahashes per second (TH/s). This high hash rate is achieved through the use of MicroBT’s proprietary chip technology, which enables the device to mine Bitcoin and other SHA-256-based cryptocurrencies with remarkable efficiency.
The Whatsminer M56 is also highly energy-efficient, consuming only 5500 watts of power to achieve its high hash rate. This level of energy efficiency is made possible through the use of MicroBT’s advanced power management technology, which optimizes the energy consumption of the device, making it one of the most cost-effective mining machines available.
The M56 features a state-of-the-art cooling system that ensures optimal performance and reliability. The cooling system comprises several large fans that work together to keep the device’s temperature at a stable level, reducing the risk of overheating and prolonging the lifespan of the device.
The device is highly customizable, with various settings that can be adjusted to optimize mining performance. These settings include fan speed, voltage, and frequency. The device’s intuitive interface makes it easy for both novice and experienced miners to use, allowing them to fine-tune the device’s settings to achieve optimal mining performance.
The Whatsminer M56 is built with high-quality materials that are designed to withstand the harsh operating conditions of mining operations. The device is equipped with advanced safety features that protect it from overvoltage, overheating, and other hazards that may damage the device.
Features of Whatsminer M56
Another key feature of the Whatsminer M56 is its versatility. The device can be used to mine a wide range of cryptocurrencies based on the SHA-256 algorithm, including Bitcoin, Bitcoin Cash, and Digibyte. The device also supports both solo mining and pool mining, making it suitable for use in any mining operation.
The device’s low noise level makes it suitable for use in residential areas or small mining farms. The device is also relatively compact, allowing it to be installed in tight spaces, making it a popular choice for home-based miners.
In terms of profitability, the Whatsminer M56 is one of the most efficient Bitcoin mining machines on the market, providing a high return on investment for miners. Its low power consumption and high hash rate make it an attractive option for miners looking to maximize their profits while minimizing their energy costs.
CONCLUSION
In conclusion, the Whatsminer M56 is a powerful and efficient Bitcoin mining machine that offers a high level of performance and reliability. Its advanced chip technology, state-of-the-art cooling system, and intuitive interface make it easy to use and highly customizable. Its versatility, durability, and energy efficiency make it a popular choice among both home-based and professional miners.
