CK- Box Set Up Question
Trying to set up a new CK-Box but when I try to set up the Yotta BC does not identity the IP address. I have tried hitting the button next to the blue light and nada. Any suggestions?
Might not be the best person to help, but since no one else did I’ll give it a shot.
I don’t use yotta. I use the web interface, and I have set up 2 boxes just fine. Maybe try that.
From a browser on the same network, just go to find.goldshell.com. It’ll tell you the IP address of the miner on the network.
that did the trick! Had resolved almost immediately… forgot where i posted the question. Sometimes it’s the easiest thing that you overlook.
