My Ck5 is no longer showing up on find.goldshell.com. Advice?
Are you on the same network?
Is it plugged in or did you switch it to wireless (if applicable)?
I’m using Ethernet. It was showing up, but not now. Still hashing away just fine. It just doesn’t show on find.goldshell.
It’s likely just an issue with goldshells website. It often has issues updating. If you’re trying to access the CK5 then download an IP scanner and you can find it that way.
Once you know the IP for the CK5, enter it in a browser and login like normal.
