Hello all, I have had my CK-Box miner(mini) for 5 days now.
I mine around 84 CKB per day and my highest earning was 93 on the second day.
I have noticed that most people average 120 ckb per day with the same miner.
I am using with F2pool.
Does my internet connection speed make a different?
Does the temperature make a difference? mine is at 84.0 / 72.4.
In other words, is there a way to tweek some settings to mine for coins?
Thank you!
120 a day seems pretty high. A couple of months ago it was around there, but network difficulty has increased so payout has decreased. I am now averaging around 80-82 ckb a day, I use dxpool. I will definitely switch pools if I can find significantly higher payouts though.
