Cost to build a Mining Rig - RTX 2070 - July 2021
July 2021 Mining Rig Build parts list: https://pcpartpicker.com/list/yk8kNP
Total System cost - $12,960.91 without frame and other components (scroll down)
Intel Celeron G5920 - $61.06
Artic Alpine CPU Cooler - $11.99
Asus PRIME H410M-E Micro ATX - $79.99
Patriot 4 GB (2x4GB) - $44.99
SSD or m.2 NVME - $32 - $35
SeaSonic Prime Gold 1200W PSU - $255.98 (You may need more or look at the Parallel miner options for cheaper)
RTX 2070 x 6 at $625+ which is the average scalper price at the time of filming.
Try to save money where you can, I mentioned alternatives throughout the video so please watch till the end before commenting. However, share your thoughts down below to help others.
Use Coupon code “SerpentX” for 10% off any of the Power Supply Kit from Parallel Miner
https://www.parallelminer.com/?wpam_id=218
Total estimate price: $4,431.99 (at time of filming)
6 x RTX 2070 = 840 watts (Tuned) or 1050 watts (stock TDP) $625 x 6 GPUs = $3750.0
Frame $63 - (https://amzn.to/36KeVY1)
Risers x 1 $30 to $65 - (https://rb.gy/rlqwmm)
6 pin to 8 pin splitters $15 to $30 - (https://amzn.to/3z0zQSC) or (https://rb.gy/5blw2p)
PCIe to 4 USB adapter - $30 - (https://rb.gy/in1oc2)
ATX power supply splitter - $10 to $15 (2x https://rb.gy/ntzonz) or (3x https://rb.gy/6ppy4v)
