Just curious, for people doing mining with desktops, what are you using to monitor the CPU/GPU temps to make sure you don’t overheat your system? Any suggested software for people to use?
Thanks. I did actually try this based off of some Google searching and came to the conclusion I shouldn’t be trying to CPU mine with my older hardware
Heat was definitely an issue and for the penny or two a day, not worth risking this CPU.
