The electrician is here and he says it will cost at least $4000-$5000. (have to replace my old panel also) is this common hore high?
The average cost to replace an electrical panel ranges from $850 to $2,500 depending on the amperage. A service panel upgrade to 100 amps costs $850 to $1,600, a 200-amp breaker box replacement costs $1,800 to $2,500, and a 400-amp electrical service upgrade costs $2,000 to $4,000
UR getting charge MAX if its a 400AMP
find someone else
he told me they were the highest in town
so i was right ? lol… im suprised they told u that… proly after u told them to leave ? lol
He admitted they were the highest in town because they were the biggest in town and had a lot of overhead. I paid $90 for the estimate
He also told me how I could use my dryers 30 amp outlet temporarily
go on yelp and search for a different company. you can send your request to multiple companies at once. explain to them what you are trying to accomplish.
ur stove got 50 proly
they even make splitters lol proly not the best idea… but would work temp. wouldnt try using stove or dry and asics at once tho… itll just pop the breaker
