Crypto Wallet for Miners
I’m sure this has been asked a lot but I appreciate your patience and feedback. What are your recommendations for crypto wallets? I will be mining BTC with an ASIC. I am completely new but learning little by little. Do you recommend any of the wallets that pay interest?
I can’t speak to BTC mining and their wallets.
I use Neuron wallet as it’s the native for Nervos.
I use Exodus wallet for LTC.
Exodus wallet can be used for BTC I think and it works with trezor hardware wallets.
Exodus it’s a multi crypto hot wallet you keep on your P.C and smartphone
I’ve only used Zelcore due to needing KDA. It seems to accept a lot of coins though including BTC.
I had a teacher by your last name, we called her Guity, but that’s another story.
Lots of folks will mine bitcoin directly into the highest interest-bearing wallet, like blockfi,
IF my L7 ever shows up that’s where I’m mining my LTC into
Awesome thank you all for this great info! I just ordered 5 ASIC miners and I am excited to get started.
Nov or Dec batch?
I ordered back in August. It was supposed to ship November
I ordered S19 Pro 110th to start with.
