i have d3 bitmain antminer the log is saying fans are to slow when starting and hw errors on boards 1 and 3 are going out the roof but all 3 boards are showing all zeros. what is causing this i am running on 220 with 20 amp breaker.
Can you copy and paste the entire log here?
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13 (xxl@armdev01) (gcc version 4.7.4 20130626 (prerelease) (Linaro GCC 4.7-2013.07) ) #22 SMP Tue Dec 2 15:26:11 CST 2014
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 65280
[ 0.000000] free_area_init_node: node 0, pgdat c06cb100, node_mem_map c0726000
[ 0.000000] Normal zone: 512 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 64768 pages, LIFO batch:15
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0933000 s9408 r8192 d15168 u32768
[ 0.000000] pcpu-alloc: s9408 r8192 d15168 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64768
[ 0.000000] Kernel command line: console=ttyO0,115200n8 init=/sbin/init
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 524288 bytes of page_cgroup
[ 0.000000] please try ācgroup_disable=memoryā option if you donāt want memory cgroups
[ 0.000000] Memory: 255MB = 255MB total
[ 0.000000] Memory: 238672k/238672k available, 23472k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0612cf0 (6188 kB)
[ 0.000000] .init : 0xc0613000 - 0xc06554c0 ( 266 kB)
[ 0.000000] .data : 0xc0656000 - 0xc06cc020 ( 473 kB)
[ 0.000000] .bss : 0xc06cc020 - 0xc0725e3c ( 360 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000356] Calibrating delay loop⦠545.07 BogoMIPS (lpj=531968)
[ 0.015441] pid_max: default: 32768 minimum: 301
[ 0.015673] Security Framework initialized
[ 0.015768] Mount-cache hash table entries: 512
[ 0.024600] Initializing cgroup subsys cpuacct
[ 0.024633] Initializing cgroup subsys memory
[ 0.024696] Initializing cgroup subsys blkio
[ 0.024834] CPU: Testing write buffer coherency: ok
[ 0.025410] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.025486] Setting up static identity map for 0x8038c820 - 0x8038c86c
[ 0.026807] Brought up 1 CPUs
[ 0.026830] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.028118] devtmpfs: initialized
[ 0.092510] pinctrl core: initialized pinctrl subsystem
[ 0.092721] rstctl core: initialized rstctl subsystem
[ 0.093214] regulator-dummy: no parameters
[ 0.093790] NET: Registered protocol family 16
[ 0.094491] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.104165] pinctrl-single 44e10800.pinmux: prop pinctrl-0 index 0 invalid phandle
[ 0.104344] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.105432] platform 49000000.edma: alias fck already exists
[ 0.105466] platform 49000000.edma: alias fck already exists
[ 0.105494] platform 49000000.edma: alias fck already exists
[ 0.106642] gpiochip_add: registered GPIOs 0 to 31 on device: gpio
[ 0.106824] OMAP GPIO hardware version 0.1
[ 0.108229] gpiochip_add: registered GPIOs 32 to 63 on device: gpio
[ 0.109548] gpiochip_add: registered GPIOs 64 to 95 on device: gpio
[ 0.110866] gpiochip_add: registered GPIOs 96 to 127 on device: gpio
[ 0.111498] of_get_named_gpio_flags exited with status 52
[ 0.111527] gpio-rctrl rstctl.3: loaded OK
[ 0.116633] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 0.119840] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.122035] cpsw.0: No hwaddr in dt. Using 3c:a3:08:1f:58:00 from efuse
[ 0.122067] cpsw.1: No hwaddr in dt. Using 3c:a3:08:1f:58:02 from efuse
[ 0.137642] bio: create slab at 0
[ 0.149781] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.150020] of_get_named_gpio_flags: canāt parse gpios property
[ 0.150312] vmmcsd_fixed: 3300 mV
[ 0.153435] SCSI subsystem initialized
[ 0.153890] usbcore: registered new interface driver usbfs
[ 0.154004] usbcore: registered new interface driver hub
[ 0.154340] usbcore: registered new device driver usb
[ 0.156463] omap_i2c 4819c000.i2c: bus 0 rev0.11 at 100 kHz
[ 0.156497] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.156693] media: Linux media interface: v0.10
[ 0.156788] Linux video capture interface: v2.00
[ 0.156906] pps_core: LinuxPPS API ver. 1 registered
[ 0.156922] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.157643] Advanced Linux Sound Architecture Driver Initialized.
[ 0.158837] Switching to clocksource gp_timer
[ 0.176837] NET: Registered protocol family 2
[ 0.177830] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.177919] TCP bind hash table entries: 2048 (order: 3, 40960 bytes)
[ 0.178009] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.178102] TCP: reno registered
[ 0.178130] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.178175] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.178671] NET: Registered protocol family 1
[ 0.179265] RPC: Registered named UNIX socket transport module.
[ 0.179286] RPC: Registered udp transport module.
[ 0.179300] RPC: Registered tcp transport module.
[ 0.179314] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.179699] Trying to unpack rootfs image as initramfsā¦
[ 1.944906] Freeing initrd memory: 12244K
[ 1.945591] CPU PMU: probing PMU on CPU 0
[ 1.945624] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 1.946252] omap2_mbox_probe: platform not supported
[ 1.950103] VFS: Disk quotas dquot_6.5.2
[ 1.950342] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.951663] NFS: Registering the id_resolver key type
[ 1.951766] Key type id_resolver registered
[ 1.951783] Key type id_legacy registered
[ 1.951849] jffs2: version 2.2. (NAND) (SUMMARY) Ā© 2001-2006 Red Hat, Inc.
[ 1.952353] msgmni has been set to 490
[ 1.955144] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.955171] io scheduler noop registered
[ 1.955187] io scheduler deadline registered
[ 1.955244] io scheduler cfq registered (default)
[ 1.959181] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.961637] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 1.962057] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 2.622852] console [ttyO0] enabled
[ 2.627376] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 89) is a OMAP UART1
[ 2.636080] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 90) is a OMAP UART2
[ 2.644716] 481a8000.serial: ttyO4 at MMIO 0x481a8000 (irq = 61) is a OMAP UART4
[ 2.653365] 481aa000.serial: ttyO5 at MMIO 0x481aa000 (irq = 62) is a OMAP UART5
[ 2.662343] [drm] Initialized drm 1.1.0 20060810
[ 2.681006] brd: module loaded
[ 2.691278] loop: module loaded
[ 2.695459] bone-capemgr bone_capemgr.8: Failed to find baseboard eeprom node
[ 2.705399] nand_get_flash_type: 2c,f1 against 2c,f1
[ 2.710928] ONFI param page 0 valid
[ 2.714601] ONFI flash detected
[ 2.717921] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron MT29F1G08ABAEAWP), 128MiB, page size: 2048, OOB size: 64
[ 2.729834] omap2-nand: detected x8 NAND flash
[ 2.734499] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 2.740082] omap2-nand: using custom ecc layout
[ 2.744946] 10 ofpart partitions found on MTD device omap2-nand.0
[ 2.751340] Creating 10 MTD partitions on āomap2-nand.0ā:
[ 2.757018] 0x000000000000-0x000000020000 : āsplā
[ 2.763829] 0x000000020000-0x000000040000 : āspl_backup1ā
[ 2.771290] 0x000000040000-0x000000060000 : āspl_backup2ā
[ 2.778707] 0x000000060000-0x000000080000 : āspl_backup3ā
[ 2.786111] 0x000000080000-0x000000240000 : āu-bootā
[ 2.794374] 0x000000240000-0x000000260000 : ābootenvā
[ 2.801265] 0x000000260000-0x000000280000 : āfdtā
[ 2.807909] 0x000000280000-0x000000780000 : ākernelā
[ 2.818882] 0x000000800000-0x000001c00000 : ārootā
[ 2.842322] 0x000001c00000-0x000003000000 : āconfigā
[ 2.866115] OneNAND driver initializing
[ 2.871855] usbcore: registered new interface driver asix
[ 2.877701] usbcore: registered new interface driver cdc_ether
[ 2.883942] usbcore: registered new interface driver smsc95xx
[ 2.890058] usbcore: registered new interface driver net1080
[ 2.896084] usbcore: registered new interface driver cdc_subset
[ 2.902378] usbcore: registered new interface driver zaurus
[ 2.908387] usbcore: registered new interface driver cdc_ncm
[ 2.915151] usbcore: registered new interface driver cdc_acm
[ 2.921106] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.929485] Initializing USB Mass Storage driverā¦
[ 2.934725] usbcore: registered new interface driver usb-storage
[ 2.941026] USB Mass Storage support registered.
[ 2.946102] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 2.952812] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 2.958056] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 2.966828] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 2.966849] musb-hdrc: MHDRC RTL version 2.0
[ 2.966864] musb-hdrc: setup fifo_mode 4
[ 2.966892] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 2.967039] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 2.972081] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 2.978101] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 2.983351] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 2.992120] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 2.992140] musb-hdrc: MHDRC RTL version 2.0
[ 2.992155] musb-hdrc: setup fifo_mode 4
[ 2.992177] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 2.992317] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 2.997362] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 3.002704] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 3.009349] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 3.017605] musb-hdrc musb-hdrc.1.auto: supports USB remote wakeup
[ 3.017708] usb usb1: default language 0x0409
[ 3.017767] usb usb1: udev 1, busnum 1, minor = 0
[ 3.017791] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.024920] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.032493] usb usb1: Product: MUSB HDRC host driver
[ 3.037707] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[ 3.043374] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 3.049334] usb usb1: usb_probe_device
[ 3.049361] usb usb1: configuration #1 chosen from 1 choice
[ 3.049427] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 3.049681] hub 1-0:1.0: usb_probe_interface
[ 3.049704] hub 1-0:1.0: usb_probe_interface - got id
[ 3.049732] hub 1-0:1.0: USB hub found
[ 3.053727] hub 1-0:1.0: 1 port detected
[ 3.057865] hub 1-0:1.0: standalone hub
[ 3.057885] hub 1-0:1.0: individual port power switching
[ 3.057903] hub 1-0:1.0: no over-current protection
[ 3.057920] hub 1-0:1.0: Single TT
[ 3.057942] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 3.057962] hub 1-0:1.0: power on to power good time: 10ms
[ 3.058017] hub 1-0:1.0: local power source is good
[ 3.058128] hub 1-0:1.0: enabling power on all ports
[ 3.059164] mousedev: PS/2 mouse device common for all mice
[ 3.067080] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 3.074858] i2c /dev entries driver
[ 3.079899] pps_ldisc: PPS line discipline registered
[ 3.085381] Driver for 1-wire Dallas network protocol.
[ 3.092652] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 3.100207] cpuidle: using governor ladder
[ 3.104537] cpuidle: using governor menu
[ 3.109097] of_get_named_gpio_flags exited with status 6
[ 3.109116] of_get_named_gpio_flags: canāt parse gpios property
[ 3.109132] of_get_named_gpio_flags: canāt parse gpios property
[ 3.109169] omap_hsmmc mmc.4: of_parse_phandle_with_args of āresetā failed
[ 3.116409] omap_hsmmc mmc.4: Failed to get rstctl; not using any
[ 3.123222] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 3.130447] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 3.137790] mmc.4 supply vmmc_aux not found, using dummy regulator
[ 3.144739] omap_hsmmc mmc.4: pins are not configured from the driver
[ 3.159045] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 3.179073] of_get_named_gpio_flags exited with status -517
[ 3.179140] platform gpio-leds.7: Driver leds-gpio requests probe deferral
[ 3.186921] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.193699] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 3.200887] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 3.208991] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 3.215340] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 3.222527] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 3.234788] usbcore: registered new interface driver usbhid
[ 3.240707] usbhid: USB HID core driver
[ 3.247602] TCP: cubic registered
[ 3.251127] Initializing XFRM netlink socket
[ 3.255695] NET: Registered protocol family 17
[ 3.260575] NET: Registered protocol family 15
[ 3.265459] Key type dns_resolver registered
[ 3.270094] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 3.278174] ThumbEE CPU extension supported.
[ 3.282684] Registering SWP/SWPB emulation handler
[ 3.288693] registered taskstats version 1
[ 3.295304] of_get_named_gpio_flags exited with status -517
[ 3.295377] platform gpio-leds.7: Driver leds-gpio requests probe deferral
[ 3.352352] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 3.358764] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 3.373267] libphy: 4a101000.mdio: probed
[ 3.377586] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 3.387830] Detected MACID = 3c:a3:08:1f:58:00
[ 3.392509] cpsw 4a100000.ethernet: NAPI disabled
[ 3.397895] of_get_named_gpio_flags exited with status -517
[ 3.397962] platform gpio-leds.7: Driver leds-gpio requests probe deferral
[ 3.406672] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 3.415951] cpu0 supply cpu0 not found, using dummy regulator
[ 3.422462] cpufreq_cpu0: failed to scale voltage up: -22
[ 3.428282] cpufreq_cpu0: failed to scale voltage up: -22
[ 3.441043] ALSA device list:
[ 3.444277] No soundcards found.
[ 3.448858] Freeing init memory: 264K
[ 3.452914] Failed to execute /init
[ 4.427235] jffs2: notice: (122) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 5.782374] net eth0: initializing cpsw version 1.12 (0)
[ 5.791278] net eth0: phy found : id is : 0x7c0f1
[ 5.796719] libphy: PHY 4a101000.mdio:01 not found
[ 5.801914] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 8.868445] libphy: 4a101000.mdio:00 - Link is Up - 100/Full
Nov 17 00:39:04 (none) local0.err cgminer: Miner compile time: Tue Nov 13 11:46:56 CST 2018 type: Antminer D3
Nov 17 00:39:04 (none) local0.warn cgminer: Started cgminer 4.9.0
Nov 17 00:39:04 (none) local0.warn cgminer[375]: bitmain_DASH_init
Nov 17 00:39:04 (none) local0.err cgminer[375]: FAN1 too slow ā¦
Nov 17 00:39:04 (none) local0.err cgminer[375]: FAN2 too slow ā¦
Nov 17 00:39:05 (none) local0.err cgminer[375]: FAN1 too slow ā¦
Nov 17 00:39:05 (none) local0.err cgminer[375]: FAN2 too slow ā¦
Nov 17 00:39:06 (none) local0.err cgminer[375]: FAN1 too slow ā¦
Nov 17 00:39:07 (none) local0.err cgminer[375]: FAN1 too slow ā¦
Nov 17 00:39:08 (none) local0.err cgminer[375]: FAN1 too slow ā¦
Nov 17 00:39:09 (none) local0.warn cgminer[375]: check_fan_speed OK
Nov 17 00:39:09 (none) local0.notice cgminer[375]: detected at /sys/class/gpio/gpio51/value chain 0
Nov 17 00:39:09 (none) local0.notice cgminer[375]: detected at /sys/class/gpio/gpio48/value chain 1
Nov 17 00:39:09 (none) local0.notice cgminer[375]: detected at /sys/class/gpio/gpio47/value chain 2
Nov 17 00:39:09 (none) local0.notice cgminer[375]: detect total chain num 3
Nov 17 00:39:09 (none) local0.notice cgminer[375]: i2c init ok
Nov 17 00:39:09 (none) local0.notice cgminer[375]: check_whether_need_update_pic_program
Nov 17 00:39:10 (none) local0.notice cgminer[375]: reset_PIC16F1704_pic_new ok
Nov 17 00:39:11 (none) local0.notice cgminer[375]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:39:11 (none) local0.notice cgminer[375]: get_PIC16F1704_software_version_new ok, version = 0x81
Nov 17 00:39:12 (none) local0.notice cgminer[375]: reset_PIC16F1704_pic_new ok
Nov 17 00:39:13 (none) local0.notice cgminer[375]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:39:13 (none) local0.notice cgminer[375]: get_PIC16F1704_software_version_new ok, version = 0x81
Nov 17 00:39:14 (none) local0.notice cgminer[375]: reset_PIC16F1704_pic_new ok
Nov 17 00:39:15 (none) local0.notice cgminer[375]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:39:15 (none) local0.notice cgminer[375]: get_PIC16F1704_software_version_new ok, version = 0x81
Nov 17 00:39:15 (none) local0.notice cgminer[375]: every_chain_reset_PIC16F1704_pic_new
Nov 17 00:39:16 (none) local0.notice cgminer[375]: reset_PIC16F1704_pic_new ok
Nov 17 00:39:18 (none) local0.notice cgminer[375]: reset_PIC16F1704_pic_new ok
Nov 17 00:39:19 (none) local0.notice cgminer[375]: reset_PIC16F1704_pic_new ok
Nov 17 00:39:19 (none) local0.notice cgminer[375]: every_chain_jump_from_loader_to_app_PIC16F1704_new
Nov 17 00:39:20 (none) local0.notice cgminer[375]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:39:21 (none) local0.notice cgminer[375]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:39:21 (none) local0.notice cgminer[375]: reset_hash_board_low 0
Nov 17 00:39:21 (none) local0.notice cgminer[375]: pic_heart_beat_func_new
Nov 17 00:39:22 (none) local0.notice cgminer[375]: reset_hash_board_low 1
Nov 17 00:39:22 (none) local0.notice cgminer[375]: reset_hash_board_low 2
Nov 17 00:39:22 (none) local0.notice cgminer[375]: reset_hash_board_low 3
Nov 17 00:39:22 (none) local0.notice cgminer[375]: every_chain_enable_PIC16F1704_dc_dc_new
Nov 17 00:39:22 (none) local0.notice cgminer[375]: enable_PIC16F1704_dc_dc_new ok
Nov 17 00:39:23 (none) local0.notice cgminer[375]: reset_hash_board_high 0
Nov 17 00:39:23 (none) local0.notice cgminer[375]: reset_hash_board_high 1
Nov 17 00:39:23 (none) local0.notice cgminer[375]: reset_hash_board_high 2
Nov 17 00:39:23 (none) local0.notice cgminer[375]: reset_hash_board_high 3
Nov 17 00:39:23 (none) local0.notice cgminer[375]: tty_init
Nov 17 00:39:23 (none) local0.notice cgminer[375]: tty_init_chain
Nov 17 00:39:23 (none) local0.notice cgminer[375]: tty_init_chain chainid = 0
Nov 17 00:39:23 (none) local0.err cgminer[375]: create rx read thread for chain 0 ok
Nov 17 00:39:23 (none) local0.notice cgminer[375]: Start A New Asic Response.Chain Id:[0]
Nov 17 00:39:23 (none) local0.err cgminer[375]: create tx read thread for chain 0 ok
Nov 17 00:39:23 (none) local0.notice cgminer[375]: open device over
Nov 17 00:39:23 (none) local0.notice cgminer[375]: tty_init_chain chainid = 1
Nov 17 00:39:23 (none) local0.err cgminer[375]: create rx read thread for chain 1 ok
Nov 17 00:39:23 (none) local0.notice cgminer[375]: Start A New Asic Response.Chain Id:[1]
Nov 17 00:39:23 (none) local0.err cgminer[375]: create tx read thread for chain 1 ok
Nov 17 00:39:23 (none) local0.notice cgminer[375]: tty_init_chain chainid = 2
Nov 17 00:39:23 (none) local0.err cgminer[375]: create rx read thread for chain 2 ok
Nov 17 00:39:23 (none) local0.notice cgminer[375]: Start A New Asic Response.Chain Id:[2]
Nov 17 00:39:24 (none) local0.err cgminer[375]: create tx read thread for chain 2 ok
Nov 17 00:39:24 (none) local0.notice cgminer[375]: open device over
Nov 17 00:39:24 (none) local0.notice cgminer[375]: tty_init_chain
Nov 17 00:39:24 (none) local0.notice cgminer[375]: check_every_chain_asic_number
Nov 17 00:39:24 (none) local0.warn cgminer[375]: check_asic_reg: Chain0 has 60 ASICs
Nov 17 00:39:25 (none) local0.warn cgminer[375]: check_asic_reg: Chain1 has 60 ASICs
Nov 17 00:39:25 (none) local0.warn cgminer[375]: check_asic_reg: Chain2 has 60 ASICs
Nov 17 00:39:26 (none) local0.notice cgminer[375]: calculate_address_interval: temp_asic_number = 64, addrInterval = 1
Nov 17 00:39:26 (none) local0.notice cgminer[375]: calculate_address_interval: CHIP_OFFSET = 0x04000000, CORE_OFFSET = 0x00800000
Nov 17 00:39:26 (none) local0.notice cgminer[375]: set_ticket_mask ticket_mask = 0x0000001b
Nov 17 00:39:26 (none) local0.notice cgminer[375]: set_frequency: frequency = 487
Nov 17 00:39:26 (none) local0.notice cgminer[375]: software_set_address_chain: chain 0 has 60 ASIC, and addrInterval is 1
Nov 17 00:39:26 (none) local0.notice cgminer[375]: Now Set [0] Chain Address
Nov 17 00:39:26 (none) local0.notice cgminer[375]: software_set_address_chain: chain 1 has 60 ASIC, and addrInterval is 1
Nov 17 00:39:26 (none) local0.notice cgminer[375]: Now Set [1] Chain Address
Nov 17 00:39:27 (none) local0.notice cgminer[375]: software_set_address_chain: chain 2 has 60 ASIC, and addrInterval is 1
Nov 17 00:39:27 (none) local0.notice cgminer[375]: Now Set [2] Chain Address
Nov 17 00:39:28 (none) local0.notice cgminer[375]: software_set_address_chain: chain 3 has 0 ASIC, and addrInterval is 1
Nov 17 00:39:28 (none) local0.notice cgminer[375]: enable_read_temperature_from_asic_chain: reg_value = 0x07007a61
Nov 17 00:39:28 (none) local0.notice cgminer[375]: select_core_to_check_temperature: diode_mux_sel = 4, vdd_mux_sel = 0
Nov 17 00:39:28 (none) local0.notice cgminer[375]: select_core_to_check_temperature_chain: diode_mux_sel = 4, vdd_mux_sel = 0
Nov 17 00:39:28 (none) local0.notice cgminer[375]: 0 calibration_sensor_offset_chain
Nov 17 00:39:28 (none) local0.notice cgminer[375]: chain:0 local:22 remote:25
Nov 17 00:39:28 (none) local0.warn cgminer[375]: Chain 0 set_temperature_offset_value_chain_sensor
Nov 17 00:39:29 (none) local0.notice cgminer[375]: set_temperature_offset_value_chain_sensor: Chain0 Sensor0 temp offset : -3,
Nov 17 00:39:29 (none) local0.notice cgminer[375]: chain:0 local:22 remote:22
Nov 17 00:39:29 (none) local0.warn cgminer[375]: Chain 0 set_temperature_offset_value_chain_sensor
Nov 17 00:39:29 (none) local0.notice cgminer[375]: 1 calibration_sensor_offset_chain
Nov 17 00:39:30 (none) local0.notice cgminer[375]: chain:1 local:22 remote:25
Nov 17 00:39:30 (none) local0.warn cgminer[375]: Chain 1 set_temperature_offset_value_chain_sensor
Nov 17 00:39:30 (none) local0.notice cgminer[375]: set_temperature_offset_value_chain_sensor: Chain1 Sensor0 temp offset : -3,
Nov 17 00:39:30 (none) local0.notice cgminer[375]: chain:1 local:22 remote:22
Nov 17 00:39:30 (none) local0.notice cgminer[375]: 2 calibration_sensor_offset_chain
Nov 17 00:39:31 (none) local0.notice cgminer[375]: chain:2 local:22 remote:25
Nov 17 00:39:31 (none) local0.warn cgminer[375]: Chain 2 set_temperature_offset_value_chain_sensor
Nov 17 00:39:31 (none) local0.notice cgminer[375]: set_temperature_offset_value_chain_sensor: Chain2 Sensor0 temp offset : -3,
Nov 17 00:39:31 (none) local0.notice cgminer[375]: chain:2 local:22 remote:22
Nov 17 00:39:32 (none) local0.notice cgminer[375]: set_temperature_offset_value_chain_sensor: Chain2 Sensor0 temp offset : -3,
Nov 17 00:39:32 (none) local0.warn cgminer[375]: Chain 0 set_temperature_offset_value_chain
Nov 17 00:39:32 (none) local0.warn cgminer[375]: Chain 0 set_temperature_offset_value_chain_sensor
Nov 17 00:39:32 (none) local0.notice cgminer[375]: set_temperature_offset_value_chain_sensor: Chain0 Sensor0 temp offset : -3,
Nov 17 00:39:32 (none) local0.warn cgminer[375]: Chain 1 set_temperature_offset_value_chain
Nov 17 00:39:32 (none) local0.warn cgminer[375]: Chain 1 set_temperature_offset_value_chain_sensor
Nov 17 00:39:32 (none) local0.notice cgminer[375]: set_temperature_offset_value_chain_sensor: Chain1 Sensor0 temp offset : -3,
Nov 17 00:39:32 (none) local0.warn cgminer[375]: Chain 2 set_temperature_offset_value_chain
Nov 17 00:39:32 (none) local0.warn cgminer[375]: Chain 2 set_temperature_offset_value_chain_sensor
Nov 17 00:39:33 (none) local0.notice cgminer[375]: set_temperature_offset_value_chain_sensor: Chain2 Sensor0 temp offset : -3,
Nov 17 00:39:33 (none) local0.notice cgminer[375]: frequency = ā487ā
Nov 17 00:39:33 (none) local0.notice cgminer[375]: dev.timeout = 620100 us
Nov 17 00:39:33 (none) local0.notice cgminer[375]: open_core_chain
Nov 17 00:39:36 (none) local0.err cgminer[375]: cgminer time error total_secs = 1700181576.583952 last_total_secs = 1.000000
Nov 17 00:39:43 (none) local0.warn cgminer[375]: API running in IP access mode on port 4028 (15)
Nov 17 00:47:40 (none) local0.err cgminer: Miner compile time: Tue Nov 13 11:46:56 CST 2018 type: Antminer D3
Nov 17 00:47:40 (none) local0.warn cgminer: Started cgminer 4.9.0
Nov 17 00:47:40 (none) local0.warn cgminer[13201]: bitmain_DASH_init
Nov 17 00:47:41 (none) local0.err cgminer[13201]: FAN1 too slow ā¦
Nov 17 00:47:41 (none) local0.err cgminer[13201]: FAN2 too slow ā¦
Nov 17 00:47:42 (none) local0.warn cgminer[13201]: check_fan_speed OK
Nov 17 00:47:42 (none) local0.notice cgminer[13201]: detected at /sys/class/gpio/gpio51/value chain 0
Nov 17 00:47:42 (none) local0.notice cgminer[13201]: detected at /sys/class/gpio/gpio48/value chain 1
Nov 17 00:47:42 (none) local0.notice cgminer[13201]: detected at /sys/class/gpio/gpio47/value chain 2
Nov 17 00:47:42 (none) local0.notice cgminer[13201]: detect total chain num 3
Nov 17 00:47:42 (none) local0.notice cgminer[13201]: i2c init ok
Nov 17 00:47:42 (none) local0.notice cgminer[13201]: check_whether_need_update_pic_program
Nov 17 00:47:43 (none) local0.notice cgminer[13201]: reset_PIC16F1704_pic_new ok
Nov 17 00:47:43 (none) local0.notice cgminer[13201]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:47:44 (none) local0.notice cgminer[13201]: get_PIC16F1704_software_version_new ok, version = 0x81
Nov 17 00:47:45 (none) local0.notice cgminer[13201]: reset_PIC16F1704_pic_new ok
Nov 17 00:47:45 (none) local0.notice cgminer[13201]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:47:46 (none) local0.notice cgminer[13201]: get_PIC16F1704_software_version_new ok, version = 0x81
Nov 17 00:47:47 (none) local0.notice cgminer[13201]: reset_PIC16F1704_pic_new ok
Nov 17 00:47:47 (none) local0.notice cgminer[13201]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:47:48 (none) local0.notice cgminer[13201]: get_PIC16F1704_software_version_new ok, version = 0x81
Nov 17 00:47:48 (none) local0.notice cgminer[13201]: every_chain_reset_PIC16F1704_pic_new
Nov 17 00:47:49 (none) local0.notice cgminer[13201]: reset_PIC16F1704_pic_new ok
Nov 17 00:47:50 (none) local0.notice cgminer[13201]: reset_PIC16F1704_pic_new ok
Nov 17 00:47:51 (none) local0.notice cgminer[13201]: reset_PIC16F1704_pic_new ok
Nov 17 00:47:52 (none) local0.notice cgminer[13201]: every_chain_jump_from_loader_to_app_PIC16F1704_new
Nov 17 00:47:52 (none) local0.notice cgminer[13201]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:47:53 (none) local0.notice cgminer[13201]: jump_from_loader_to_app_PIC16F1704_new ok
Nov 17 00:47:54 (none) local0.notice cgminer[13201]: reset_hash_board_low 0
Nov 17 00:47:54 (none) local0.notice cgminer[13201]: pic_heart_beat_func_new
Nov 17 00:47:54 (none) local0.notice cgminer[13201]: reset_hash_board_low 1
Nov 17 00:47:54 (none) local0.notice cgminer[13201]: reset_hash_board_low 2
Nov 17 00:47:54 (none) local0.notice cgminer[13201]: reset_hash_board_low 3
Nov 17 00:47:54 (none) local0.notice cgminer[13201]: every_chain_enable_PIC16F1704_dc_dc_new
Nov 17 00:47:54 (none) local0.notice cgminer[13201]: enable_PIC16F1704_dc_dc_new ok
Nov 17 00:47:55 (none) local0.notice cgminer[13201]: enable_PIC16F1704_dc_dc_new ok
Nov 17 00:47:55 (none) local0.notice cgminer[13201]: reset_hash_board_high 0
Nov 17 00:47:55 (none) local0.notice cgminer[13201]: reset_hash_board_high 1
Nov 17 00:47:55 (none) local0.notice cgminer[13201]: reset_hash_board_high 2
Nov 17 00:47:55 (none) local0.notice cgminer[13201]: reset_hash_board_high 3
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: tty_init
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: tty_init_chain
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: tty_init_chain chainid = 0
Nov 17 00:47:56 (none) local0.err cgminer[13201]: create rx read thread for chain 0 ok
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: Start A New Asic Response.Chain Id:[0]
Nov 17 00:47:56 (none) local0.err cgminer[13201]: create tx read thread for chain 0 ok
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: open device over
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: tty_init_chain chainid = 1
Nov 17 00:47:56 (none) local0.err cgminer[13201]: create rx read thread for chain 1 ok
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: Start A New Asic Response.Chain Id:[1]
Nov 17 00:47:56 (none) local0.err cgminer[13201]: create tx read thread for chain 1 ok
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: tty_init_chain chainid = 2
Nov 17 00:47:56 (none) local0.err cgminer[13201]: create rx read thread for chain 2 ok
Nov 17 00:47:56 (none) local0.notice cgminer[13201]: Start A New Asic Response.Chain Id:[2]
Nov 17 00:47:56 (none) local0.err cgminer[13201]: create tx read thread for chain 2 ok
Nov 17 00:47:57 (none) local0.notice cgminer[13201]: check_every_chain_asic_number
Nov 17 00:47:57 (none) local0.warn cgminer[13201]: check_asic_reg: Chain0 has 60 ASICs
Nov 17 00:47:57 (none) local0.warn cgminer[13201]: check_asic_reg: Chain1 has 60 ASICs
Nov 17 00:47:58 (none) local0.warn cgminer[13201]: check_asic_reg: Chain2 has 60 ASICs
Nov 17 00:47:58 (none) local0.notice cgminer[13201]: calculate_address_interval: temp_asic_number = 64, addrInterval = 1
Nov 17 00:47:58 (none) local0.notice cgminer[13201]: calculate_address_interval: CHIP_OFFSET = 0x04000000, CORE_OFFSET = 0x00800000
Nov 17 00:47:58 (none) local0.notice cgminer[13201]: set_ticket_mask ticket_mask = 0x0000001b
Nov 17 00:47:58 (none) local0.notice cgminer[13201]: every_chain_get_PIC16F1704_freq_new
Nov 17 00:48:01 (none) local0.notice cgminer[13201]: set_frequency: frequency = 537
Nov 17 00:48:01 (none) local0.notice cgminer[13201]: software_set_address_chain: chain 0 has 60 ASIC, and addrInterval is 1
Nov 17 00:48:01 (none) local0.notice cgminer[13201]: Now Set [0] Chain Address
Nov 17 00:48:01 (none) local0.notice cgminer[13201]: software_set_address_chain: chain 1 has 60 ASIC, and addrInterval is 1
Nov 17 00:48:01 (none) local0.notice cgminer[13201]: Now Set [1] Chain Address
Nov 17 00:48:02 (none) local0.notice cgminer[13201]: software_set_address_chain: chain 2 has 60 ASIC, and addrInterval is 1
Nov 17 00:48:02 (none) local0.notice cgminer[13201]: Now Set [2] Chain Address
Nov 17 00:48:03 (none) local0.notice cgminer[13201]: software_set_address_chain: chain 3 has 0 ASIC, and addrInterval is 1
Nov 17 00:48:03 (none) local0.notice cgminer[13201]: enable_read_temperature_from_asic_chain: reg_value = 0x07007a61
Nov 17 00:48:03 (none) local0.notice cgminer[13201]: select_core_to_check_temperature: diode_mux_sel = 4, vdd_mux_sel = 0
Nov 17 00:48:03 (none) local0.notice cgminer[13201]: select_core_to_check_temperature_chain: diode_mux_sel = 4, vdd_mux_sel = 0
Nov 17 00:48:03 (none) local0.notice cgminer[13201]: 0 calibration_sensor_offset_chain
Nov 17 00:48:03 (none) local0.notice cgminer[13201]: chain:0 local:40 remote:42
Nov 17 00:48:03 (none) local0.warn cgminer[13201]: Chain 0 set_temperature_offset_value_chain_sensor
Nov 17 00:48:04 (none) local0.notice cgminer[13201]: set_temperature_offset_value_chain_sensor: Chain0 Sensor0 temp offset : -2,
Nov 17 00:48:04 (none) local0.notice cgminer[13201]: 1 calibration_sensor_offset_chain
Nov 17 00:48:04 (none) local0.notice cgminer[13201]: chain:1 local:40 remote:41
Nov 17 00:48:04 (none) local0.warn cgminer[13201]: Chain 1 set_temperature_offset_value_chain_sensor
Nov 17 00:48:04 (none) local0.notice cgminer[13201]: set_temperature_offset_value_chain_sensor: Chain1 Sensor0 temp offset : -1,
Nov 17 00:48:04 (none) local0.notice cgminer[13201]: 2 calibration_sensor_offset_chain
Nov 17 00:48:05 (none) local0.notice cgminer[13201]: chain:2 local:43 remote:45
Nov 17 00:48:05 (none) local0.warn cgminer[13201]: Chain 2 set_temperature_offset_value_chain_sensor
Nov 17 00:48:05 (none) local0.notice cgminer[13201]: set_temperature_offset_value_chain_sensor: Chain2 Sensor0 temp offset : -2,
Nov 17 00:48:05 (none) local0.warn cgminer[13201]: Chain 0 set_temperature_offset_value_chain
Nov 17 00:48:05 (none) local0.warn cgminer[13201]: Chain 0 set_temperature_offset_value_chain_sensor
Nov 17 00:48:05 (none) local0.notice cgminer[13201]: set_temperature_offset_value_chain_sensor: Chain0 Sensor0 temp offset : -2,
Nov 17 00:48:05 (none) local0.warn cgminer[13201]: Chain 1 set_temperature_offset_value_chain
Nov 17 00:48:05 (none) local0.warn cgminer[13201]: Chain 1 set_temperature_offset_value_chain_sensor
Nov 17 00:48:05 (none) local0.notice cgminer[13201]: set_temperature_offset_value_chain_sensor: Chain1 Sensor0 temp offset : -1,
Nov 17 00:48:06 (none) local0.notice cgminer[13201]: set_temperature_offset_value_chain_sensor: Chain2 Sensor0 temp offset : -2,
Nov 17 00:48:06 (none) local0.notice cgminer[13201]: frequency = ā537ā
Nov 17 00:48:06 (none) local0.notice cgminer[13201]: dev.timeout = 562356 us
Nov 17 00:48:06 (none) local0.notice cgminer[13201]: open_core_chain
Nov 17 00:48:09 (none) local0.err cgminer[13201]: cgminer time error total_secs = 1700182089.721564 last_total_secs = 1.000000
Nov 17 00:48:11 (none) local0.err cgminer[13201]: D1 0: work 7f not find error
Nov 17 00:48:16 (none) local0.warn cgminer[13201]: API running in IP access mode on port 4028 (15)
ok here is the log
Summary
| Elapsed | GH/S(RT) | GH/S(avg) | FoundBlocks | LocalWork | Utility | WU | BestShare |
| 1h20m29s | 19,322.57 | 19,226.26 | 0 | 28,460 | 3.81 | 291.86 | 14,471 |
Pools
| Pool | URL | User | Status | Diff | GetWorks | Priority | Accepted | Nonce# | DiffA# | DiffR# | DiffS# | Rejected | Discarded | Stale | LSDiff | LSTime |
| 0 | stratum+tcp://dash.ss.poolin.one:443 | Alive | 64.0000 | 175 | 0 | 307 | 691,786 | 23,424 | 64 | 0 | 1 | 2,756 | 0 | 64 | 0:00:04 | |
| 1 | stratum+tcp://dash.ss.poolin.one:1883 | Alive | 128.0000 | 1 | 1 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | |
| 2 | stratum+tcp://dash.ss.poolin.one:700 | Alive | 128.0000 | 1 | 2 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | |
| Total | 177 | 307 | 691,786 | 23,424 | 64 | 0 | 1 | 2,756 | 0 | |||||||
| HW | 3,246 | 0.4692% | 13.8576% |
AntMiner
| Chain# | ASIC# | Frequency | GH/S(RT) | HW | Temp(PCB) | Temp(Chip) | ASIC status |
| 1 | 60 | 537 | 6401.50 | 459 | 54 | 74 | oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooo |
| 2 | 60 | 537 | 6326.35 | 0 | 52 | 73 | oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooo |
| 3 | 60 | 537 | 6594.73 | 2,787 | 56 | 76 | oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooooooo oooo |
Fan# Fan1 Fan2
Speed (r/min) 6,000 5,640
i dont think this is normal
Look at the accepted/rejected shares, 1 accepted, 2700 discarded, this might be a pool error. It says your fans are running at 6000? Does it look and sound like itās running max? I would suggest trying different pools. I had the same issue with scrypt mining with the bluestar L1 it would only work on one pool. Iād also suggest doing a firmware update if there is one
i did update to the latest firmware from 2018 i also have the fans set to 100% ive tryed 2 other pools and same thing. do you think i might have a faulty control board?
Iād try the following
- try all the pool ports and see how many get accepted/rejected
-try different pools and try all their ports
Just trying to understand, youāve set your fans on max but can you see they are working?
I might not be correct, but my understanding is your miner is hashing but the pool is rejecting the shareās because they are all getting discarded which might be a port issue or a pool issue or your miner might not be suited for that pool due to firmware or hardware. I donāt think the control board is faulty because itās connecting to the pool. I might be wrong but trial and error is what will help you figure it out
all right thank you for your help
ok i just found out that i am missing all of my global settings in the firmware. is there a way to do a fresh install of firmware?
Go here BITMAIN and do the TF service pack onto SD card, Iām not familiar with that control board, like the S19 boards you unplug everything except the power, turn it on with the SD in and wait for the green light. Iād look up more tutorials on your board. Good luck
