Hmm… msOS also seem to be different versions for 500 and 5000-series. Can I use any of them if I intend to have both GPU’s on same rig, and in that case which one?
first one you can use for both gpu just some stats maybe not working on 5000 series as is different and tune you need made manually for 5000 series as tune will be set automatically for 500s gpus for 5000 you need change manually for etch non 500 s gpus. it simple to do just make sure miner is on idle not mining as after you done tune for 500 and 5000 you need reboot rig to config your tune other wise your rig is crash. also all rigs shut be not mixed in your case you need to have 1x rig 570 and 1x 5700 in future
Thanks! I actually tried the middle one yesterday as it had the highest version number and I hoped it should be backwards compatible. Right now I’m getting slightly more than 25 MH/s per 570 and just over 50 MH/s on the 5700 with standard settings. I’ll try to play around with settings today, which I didn’t have time for yesterday. I might change to v1.4 also as per your suggestion. How high do you think I can push them?
on 570 you shut get 31-32.2mhs core voltage 886 core 1180 mem 2180 at 86watt bios moded 5700 55mhs at 108watt
