Hi, I Live in the UK where electricity is still fairly expensive… (£0.24) ish per Kwh
so I am usually looking for low power miners
I saw this one on Aliexpress, and wondered what people thought?
Cheers,
Cheers,
It looks like a lottery ticket miner. You’re not going to make any BTC from it, but you could hit a block and win the lottery.
If it were me, I’d go for one that’s got RGB.
Cheers.
RGB? I’m guessing that’s not Red / Green / Blue?
you have a better chance in winning the normal lottery from the local gas station than hitting a block on those. if your looking for low powered mining check out goldshells (some can be profitable like the alph box but most arent) or a chia miner (long roi but low power consumption) you can do https://evergreenminer.com/ or
https://www.badgerminers.io/
