I am having issues collecting my profits for the DX Pool. I am unable to bind phone number. Been less then 24 hours I do see my profits, but I don’t see how to put them in my wallet.
Any feedback be useful thank you.
I had the same issue with them. They had to go in and correct my phone number themselves. Just send them an email and they should be able to fix you up. It did take a few days, but they corrected it.
Also… I switched to ViaBTC and it has been great. Couldn’t get it to work initially (that is why I went with DxPool first), but now it is running smooth. The ViaBTC app is also great for monitoring when I am not home.
ViaBTC work with HD-Box Miner?
Issue all solved!
I was able to get HD-BOX miner to work with DxPool.
Still Weird Issues though:
I did not buy the PLUG from Goldshell: I bought a GD 80 Power supply brand (GameMAX 750 WATT 80 gold.
Other then that the HD-Box miner is weirdly more quiet then my Library Miner and runs smoothly now.
How everyone else enjoying the miner?
Btw, you can buy a jumper cap to clip to your 24-pin - it’s a bit more professionally done so you don’t have to worry about shorts.
yeah that jumper is awesome.
KD-Box back on sale again!
