What wallets work with dxpool ?
What coin are you looking to mine?
What exactly are you planning to do?
LTC and doge coin
Lite coin amd doge coin
Last time I checked they did not let you withdraw Litecoin to Mweb wallets which is currently only available in Litecoin core wallet as far as I’m aware so you should be able to send/receive to any wallet that isn’t Mweb in Litecoin core, you can still use a non Mweb address in Litecoin core which will be Legacy or Native Segwit (I think, If im wrong someone will correct me) I’ve never used an exchange so I’m not sure about sending/receiving from an exchange. you can always download Litecoin core and Dogecoin core here which has a wallet and is non KYC, just make sure you write down your password on paper offline (incase you have a keylogger etc, never allow it to be visible in front of a webcam or camera) and backup your wallet onto multiple USB or hardrives
Good luck happy mining
If you’re trying to keep tabs on your holdings and transactions, using a solana wallet tracker can be really helpful. Some pools don’t clearly display rewards or wallet balances, so having an easy way to track everything makes a difference. I’ve run into similar situations where payouts seemed off, and tracking my wallets separately helped me confirm what was actually happening. Double-checking on different platforms has saved me some headaches.
I’ve been using CoinScryp to keep an eye on my mining payouts across different wallets, and it works well for monitoring holdings like LTC and DOGE without hassle. For Dxpool, stick with Legacy or Native Segwit addresses—I personally use Litecoin Core for non-KYC storage, and it’s fine.
